Configure Maximum EAP Clients
Use this procedure to configure the maximum EAP clients allowed on the port at one time.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the maximum EAP clients:
    eapol multihost eap-mac-max <0-32>
    eap-mac-max is also used to provide EAP and NEAP separation functionality. By default the EAP clients are enabled per port and eap-mac-max limit is 2. If eap-mac-max is set to 0 then EAP client authentication is disabled.
Configure the maximum EAP clients allowed on the port at one time.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/1
Switch:1(config)#eapol multihost eap-mac-max 10
The following table defines parameters for the eapol multihost eap-mac-max command.
Variable
Value
<0–32>
Specifies the maximum EAP clients allowed on the port at one time. The default is 2.
